But at 120v, not at 12v
That base is called "Edison base" and I suspect there's a very small market for what Tom needs (at 12v). Even if you search the web specifically for "12v edison base led light bulb" you come up with a lot of related links that really don't have the item. They're out there, but you need to dig a little.
