I would seat the goosneck in Marine Tex as
In Response To: rivets? ()
as I tightened the appropriate sized course thread bolts. I had the same issue 10 years ago and it's held up fine. There isn't any sign of corrosion behind or around the gooseneck and it looks like it was put on yesterday. I wouldn't do this if I ever planned on taking it off. You could get it off by using heat but you would have to work at it.
