can't run the good stuff then install fuel shut off valves and run the engines out of gas every time. I use the "Red Dye" high sulfur fuel in Brendon as well. The station I get it from has non alcoholic fuel high octane, racing fuel which is crazy expensive and about every other kind of fuel you can think of. Maybe you can locate a station like that in your area.
