Return to Index
Read Responses
Isn't tingling AC?
In Response To:
for the electrically minded
Were you barefoot?
not AC
Understood....
Isn't tingling AC?
I was thinking the same thing about AC
The windlass body is "grounded"?
Only that if you are feeling a leak, you're forming a pretty good ground.
analog phone lines have a 90 volt ring signal.
AC at 20 hz
12V windlass? Not plugged in at the time? Inverter not on?
