Tee into 1 1/2 inch drain hose
I have a 1 1/2 inch deck drain hose that goes down to a seacock. I want to tee into this drain hose, put a plastic or bronze connector between a section of the hose, and in addition add a 5/8 inch drain hose from an Air conditioning pump so that it drains out the same hose. Can anyone suggest a Tee that would allow this? If none is available, i could get some sort of 1 1/2 in bronze connector with and maybe tap into and thread a fitting with a hose barb for the 5/8 diam. A/C hose.
Any ideas greatly appreciated, as I have not been able to find anything suitable.
