you're right SG...
Actually the deck drain I am talking about does, in fact go down to a thru hull located just above the water line. I said it drained to a sea cock, but that wasn't accurate. Of course, with A/C running you do want to be able to see/hear the tell tale water stream so that you know everything is circulating and draining properly. Good catch!
