The stations here with the e-free run about a buck above regular. I've thought about running a tank or through the car to check the mileage. Should be a bit better since the ethanol has a lower energy specific but no doubt the difference will not be nearly enough to offset the cost. (Don't get me going on diesel! Spend a lot of time in Germany for work and diesel is cheaper than gasoline)
