that needs to be taken apart occasionally is two ring connectors nut and bolted together. Then use the stretchy rubber insulation tape covered by a number of electrical tape passes. As an example, I prefer 1/4 x 20 x 1/2 inch nut and bolt assembly with a number 10 wire and ring connectors for things like solar panels.
