of my solar panels and the connection is made at the panel on all three. The only protection from the enviroment is the fact that the connections are made under the panels. I wrap each wire seperatly and then cover with plastic electrical tape. My wind generator has the connection made below deck. If you want to have additiomal protection first slide a length of large enough shrink tubing and really put the isseue to bed
