Is the height really needed?
The way I see it (Wi-Fi being line-of-sight) the reason for height is to "see" over other boat's superstructures in a marina. In a marina the obstructions are the major signal limiter. Out in an anchorage where distance is more of a signal limiting factor, height is probably less important to achieve line of sight.
