Re: Low tank / A hose? Have you
In Response To: Re: Low tank ()
Have you checked your rubber hoses. If one collapsed on the inside, you might not notice it? Blowing through a collapsed hose would not necessarily show anything. Over time a hose could go bad and start to disintegrate from the inside or maybe it has a lining going bad.
