Return to Index
Read Responses
Thanks for the tip
In Response To:
Re: Puzzle about diesel fuel vacuum
Will try cleaning it
Vacuum Gauge
Thanks Larry
Is it only the drag pointer or the gauge?...
It's the gauge
Low tank
Re: Low tank
Re: Low tank / A hose? Have you
Good thought
Have you moved the gauge?
Re: Have you moved the gauge?
How do I test it?
Test.
Some guages have adjustment screws on the "back" to calibrate
Thanks for the tip
