I will need to get to the Hunter with my camera. I did find the image below on-line, that silver handle is to pull the panel out of its mounts to get to the back side. The AC panel is on the right, the two switches you see are for the water heater and battery charger. On the back side their are two additional breaker switches, one marked outlets, the other marked microwave, both are on. The DC panel on the left also has a series of switches on the back side, cabin lights, fridge, 12v outlet, all of those are on as well. It is one of two DC panels, the other is located around the bulkhead in the aft cabin, has additional breakers(no switches), does not come out.
