Return to Index
Read Responses
That is very comparable to my Allied 36
In Response To:
Re: Actual MPG for the past 120 miles???
I run at 6 knots on about 0.45 gal/hr. Typical cruising rpms are 1550.
Only...we uh, older types can't remember what boat you have...
Sabre 386, 2005. 40 hp Yanmar 3jh4e with an SD-50 saildrive. Gori folding 3 blade prop...
We beat you on dog food. 28 pounds of dogs.
Not at all bad...
Not sure what your point is Todd
Just poking you with a stick
Engine spinning faster and consuming less fuel is counterintuitive, isn't it?
Power required to move the boat is determined largely by speed, displacement and waterline length...
Spinning more quickly without load, yes...
