Re: It's not so simple, Steve / That's why you take your foot off the switch. The start up
In Response To: It's not so simple, Steve ()
load or even the stall load should be accounted for in the 125% of full load. You can't fuse for something that exceeds the capacity of the wire. What other solution would you recommend? Once you have wire that is large enough to eliminate any voltage drop, anything larger is just a lot of weight. If you run larger wire and a larger fuse then you run the risk of melting the motor and never tripping the breaker.
