Return to Index
Read Responses
Could you describe the 'lifting' and how long ago the paint was applied?
In Response To:
What kind of paint stripper do you guys use to strip 2 part LP paint?
I think you're out of luck.
I think you're right. I used heavy stripper on my Awlgripped hull.
Re: I think you're out of luck. / I tried a SS wire brush and it did zip. I was
Stephen, did you try Petite?
Re: I think you're out of luck. /. I called Petite and they said the
Soda blasting is an art -
Some say this softnens gel coat. I'd be careful.
Hi Steve, how about contacting Petit?
Re: Hi Steve, how about contacting Petit? / Thanks all. It sounds
I'm late in asking but what are you gonna do? Repaint? Get back to gelcoat? What's your goal?
Re: I'm late in asking but what are you gonna do? What's your goal? / re-paint and have it stick.
Is it something that just sanding and re-prepping the surface for a paint coat can handle?
Re: Is it something that just sanding and re- / Not really. The diamond plate non skim precludes
Re: Could you describe the 'lifting' and how long ago the paint was applied? / I painted
I'm seeing custom made (easy peasy) sanding "wedges" with 150 grit wrap being as long as....
Re: I'm seeing custom made (easy peasy) / well, if it's going to get done
