Re: What context was that statement made in, Craig?
The enquiry by the owner of the 2009 H33 was in regards to the correct size prop for the boat. The PO had swapped out props and the new owner was wondering what the boat originally came with. There were two emails from M-H, this is the first in it's entirety less the signature name.
"To preface, the company that built your boat, Hunter Marine, no longer exists as of 2012. We at Marlow-Hunter are building new Marlow-Hunter boats. However, we do attempt to support existing Hunter owners with the information we have available.
16 x 11 RH 2-blade, cruising is 3849 RPM.
Regards,"
BTW, according to posts following the one above, the cruising RPM for the Yanmar 3GM on the Hunter is nowhere near 3849.
