When I went to charge this battery, the grease I put on the posts last spring looked like it had bloomed. I wiped the grease of and cleaned it with a wire brush. Then I looked at the nut and noticed it was eaten away on the bottom half. The threads on the nut and the post are fine. Kind off weird only the outside of the nut was eaten and only on the positive post. The battery seems to be fine otherwise.
