10 tubes of TDS caulking in all(amazingly, I estimated correctly). Photos taken after sanding off the excess caulking followed by a wipe with paint thinner. There is a lot more grip in new caulking, almost 'tacky'. You feel the 1/8" strips of rubber running your hand across the glassy smooth, wood decking.
Removing the deck margin boards to expose the plywood flange. The final resting place,down the hill, will be ready first of the week. Hopefully the travel lift operator can find a spot to fit in this 'launch'.
