Here's a pic of the old 'joint'.
The old cockpit 'deck' was hung from the coamings with screws alone. And I would say they're a little short. Still with no adhesive, they did the job for 50 or so seasons. You can see the extent of surface wear along the joint. Next to it is an inside corner of the old cockpit well.
