Return to Index
Read Responses
Re: Talk about exciting new products! Self cutting cable ties!
In Response To:
Do they rust at the cutter?
If you clip the ties with a fingernail clipper, there will be no sharp corners. I keep one for that
This is what I use ...
Re: This is what I use ... / You can use any pair of pliers by just
That's the way I do it, works very well.
Me too. I must be cutting off 3 old ties, to each new one I'm installing.
BTW, I use side cutters to remove the old ones. Never saw the self cutting until now.
