Return to Index
Read Responses
Did you ever leave vinegar in it for a long time?
In Response To:
Peggy - Raritan PHIIC Questions
It will distort the rubber parts.
Re: Did you ever leave vinegar in it for a long time?
I think you have the wrong part
Re: thanks Larry - you are correct!
Do you use any chemicals or deodorizer?
Re: I only use Raritan chemicals
Re: Red versus black joker valve?
Tip when you reassemble
Re: Tip when you reassemble - thanks Larry!
Re: Red versus black joker valve? Black is the improved version
Re: Red versus black joker valve? Black is the improved version . . . Clubs or spades?
