Return to Index
Read Responses
Re: Varnish is a pretty good sealer, but be SURE you add some non skid of some sort..
In Response To:
Varnish is a pretty good sealer.
varnish and wet feet don't mix well, and feet in a dinghy will for sure be wet some times
Special project: Dingy floor boards
Re: Special project: Dingy floor boards
I'd seal only the edges, I think. Easier to repair the varnish on the flats. BUT...I'd use.......
definitely real wood
I'm good with Tom on this. Sounds like the usage won't require more.
