Its almost time to hook up the nav and spreader lights. For my keel-stepped mast the connections are inside the cabin, just under the cabin top, so the connectors do not need to be totally waterproof. I think I need a two, a three and a four pin connector or some combination. My lights are almost all LED, so the connectors don't need to handle more than an amp at the most. They can't be too big, as there is less than an inch between the mast and collar that they will need to fit through when stepping the mast. Strain relief would be good as well.
I could use a terminal strip, but don't really have a good spot for it.
Google usually works for me, but although it turned up lots of connectors, I couldn't really tell if any of them were what I wanted.
Thanks in advance.
