Return to Index
Read Responses
Thanks, considering this, I would need an attractive box,
In Response To:
I use
as it will be exposed in the main cabin. Probably a couple plugs wouldn't look any better.
Need Help Please. What do you use for mast wiring connectors?
I use
I made a small teak box to cover the terminal strip.
Wiremold
I use Ancor/Marinco Dry Seal Connectors for ... (pic)
The Boxes (link)
Nice work, looks great, easy to check & work on ! (nm)
Thanks all, I think a terminal strip and nice cover are the way I will go
