Return to Index
Read Responses
Using a PC and a USB GPS there should be no....
In Response To:
GPS and USB
need to edit the port. I am using a Garmin and as soon as I had isntalled the driver, it worked.
Laptop & GPS question
You are going to need to use a USB port (link)
GPS and USB
Progress, of sorts...
Here is an instruction on resetting your COM ports
You don't need to do THAT to reassign com ports for a USB device
Problem solved...
day late, dollar short
A photo (pic)
How long does that swcan take?
Not long
SeaClear virtual com port
