this is the antenna I purchased for our Alpha adaptor
We bought the Alpha because we have a Macintosh and the Eugenics only wprks on PC's. The other thing I liked is the fact that it uses two USB ports. It needs both port for the power as one won't supply enough prwer for the 1/2 watt it uses. I can only think that it must be more powerful than the Euginics as it uses only one port for power.
This is the antenna we use it with. If not this antenna, something like it (this is the one we purchased.). http://www.pcliquidations.com/item.asp?id=2067
Here is the Alpha on Amazon http://www.amazon.com/Adapter-Wardriving-Extension-Strongest-Market/dp/B000QYGNKQ/ref=sr_1_1?ie=UTF8&s=electronics&qid=1258430749&sr=8-1
You may want an extention cable as I think the one with it is only 8 feet making it very limiting.
I don't think you can go wrong with the Alpha 1/2 watt adaptor and the antenna
A good set would be the Alpha 1/2 watt, the 9DB antenna and an extension cable. At least that's what we have and it works fine. But then, the WaveRv USB unit works fine for us also.
Good Luck.
