Return to Index
Read Responses
Rich should Rydlyme be used
In Response To:
Correction ... thats "CAN" be dumped overboard when (nm)
in both the raw water and freshwater sides of the coolant system? Thanks
Anyone know at what temp (more or less) freshwater from the heat exchanger should be (i.e., after it's been cooled in
Overheating
The outlet temp on a Hx is 'engine dependent' ......
I'm with RichH on this one. You will probably need to descale the coolant side.
Flow and temp... (link)
Note on IR temperature "guns"
Re: Note on IR temperature "guns"
