I think yo need a LOT more than 2 thou per inch shaft diameter
In Response To: Plain bearing clearances ()
My first boat had 0.010" clearance, which was about 3 thou/inch.
Rudder became almost impossible ot move after about 3 months in the water.
There may be some guidance on web sites of the plastic manufacturers, particularly for the higher-tech ones (as opposed to good old and cheap Delrin)
