Return to Index
Read Responses
Yes it fits the same hole, and the chandlers or online sellers will have it
In Response To:
Larry, is the linklite round like the
I have a "Link 10" and I'm getting an error
Have you tried a reset?
Hi Ed, Denny and I are back in PV
Did you try a full reset?
Thanks for the Downloads. I did a
I don't think Xantrex makes it anymore
That's a bummer because I'm flying to
Xantrex might help with a susggestion you, call them.
It's out of warranty -- so just get the LinkLite battery monitor instead
If you get pressed for time
Hi Ed, Does it fit in
XBM also fits the same hole
There is a picture of one at
Any alternatives to Xantrex Monitors
Lots. Search the web for: battery monitor 12v
I've had great luck with my XBM --nary a problem in five years...which
David...
Depending on your needs, you
Really like my Link 2000,
I used to have a Link 2000 that emitted RFI on the marine VHF band
I think it was the Inverter/Charger and not the Link itself that causes the RFI issues.
No inverter charger. My error: It was a Link 20 (not Link 2000) and that was what caused the noise.
