Return to Index
Read Responses
Lots. Search the web for: battery monitor 12v
In Response To:
Any alternatives to Xantrex Monitors
I have a "Link 10" and I'm getting an error
Have you tried a reset?
Hi Ed, Denny and I are back in PV
Did you try a full reset?
Thanks for the Downloads. I did a
I don't think Xantrex makes it anymore
That's a bummer because I'm flying to
Xantrex might help with a susggestion you, call them.
It's out of warranty -- so just get the LinkLite battery monitor instead
Larry, is the linklite round like the
Yes it fits the same hole, and the chandlers or online sellers will have it
If you get pressed for time
Hi Ed, Does it fit in
XBM also fits the same hole
There is a picture of one at
I've had great luck with my XBM --nary a problem in five years...which
David...
Depending on your needs, you
Really like my Link 2000,
I used to have a Link 2000 that emitted RFI on the marine VHF band
I think it was the Inverter/Charger and not the Link itself that causes the RFI issues.
No inverter charger. My error: It was a Link 20 (not Link 2000) and that was what caused the noise.
