Return to Index
Read Responses
Me too! I think you just got a bad one John.
In Response To:
I took Peggie's advice on this 3 years ago.
Diverter valve
IMO Whale is the best choice
Definition of "secured"
Defined in 33 CFR 159.7
Whale Y valve .. I'll respectfully disagree with Peggy ...
Could be a lemon
Had Two, no problem.
Had three, no problem. One is upside down!
Your tanks should be vented, no pressure build-up
Your problem has nothing to do with the y-valve...
Tank IS vented, and is clear, that's not the problem ...
Whale it is!
