Return to Index
Read Responses
West G-Flex epoxy will work very well
In Response To:
Glue for Teak
As the others said, wipe the surfaces down with acetone before applying epoxy.
Glue for Teak
Wipe edges to glue with acetone before applying glue..whatever you use.
I've always used epoxy after cleaning the edges with acetone
thick boards will not work the way you are going to do it
Do you mean wide boards? I agree with putting thinner wood on......
A friend used black 5200 to look like caulk.
Wow! Glad I asked.
It was interior work but I used some 5200
