Return to Index
Read Responses
exactly
In Response To:
The positions don't matter.
Anyone know how I can calculate the CFM of air that my diesel consumes.
your engine mfg should have that info readily available....
Does this look right?
I think you want to divide by 2 instead of multiply.
oops...I think we are both wrong!
Are the RPM's measured at the end of the crank shaft or the end of the transmission?
I've not seen readings for other than engine rpm.
I beleive that's right...So I think for our Yanmar 4JH4-HTE
exactly
THe engine needs to shut off as you hit the fire extinguisher unless you're using a foam vs. "gas"?
ABYC spec:
I think the more important spec is what your insurance company says....
The issue is that the gas will quell the fire -- but
I thought the issue was more that
The gas displaces the Oxygen
If you install a fixed fire extinguisher system you also need...
Saftey for person in engine room
If it's the same beautiful canoe sterned boat I remember...
It is tight but I have had 2 people in there at once.
Is this the same Coast 34
Wow I love looking at picts of other Coasts
