Return to Index
Read Responses
I can't imagine the tank supporting the seat top..
In Response To:
PE or PP might not support the seat
water tank wild idea...
Plan B...polyethylene or polypropylene...
Yeah but that would mean cutting out the old tank and squeezing in a new tank.
Not suggesting you replace the tank, just the lid with PE or PP instead of plexi
My tank lid supports the V-berth
Oh. Hhhuh...mmmmm.....sounds of discovery
I don't believe that you
Yeah, they do have scrap pieces...
I think you could pretty much use any kind
My last two boats came with acrylic plastic sheet covers on the fresh water tank
I have to use a gasket anyway...
Plex drilling takes special "bits"
Drilling plastic
Thanks, good idea...
Gene- it really doesn't take 'special bits' I've drilled a ton of plexi with just plain twist bits- but
Or you can use countersunk washers
My recommendation is to get the special bit if you can.....
Here's a pic of the special bit for boring acrylic:
Uh, that'd be "grabbed". Believe me, I've wasted some acrylic in my time.
I might be able to get it from the plastic folks themselves...
Check the different characteristics between plexi and lexan to see what you want.
Lexan (polycarbonate) is not likely to crack, but it's not as rigid as Plexi (acrylic)
I almost never disagree with Charlie on anything..but this is one.
PVC
Lots of PVC is not rated by FDA (lead)
Maybe that explains why I seem to be getting dumber every day.
Good feed back from ALL... this is why I come back here over and over again... THANKS
Nice boat!
I would use lexan (polycarbonate) instead of plexiglass...
I was thinking about Lexan...
Replace the whole damn thing
Hi Rich. What kind of product
Not a hijack... good question.
Epoxy Lining resins for potable water tanks
Thanks Rich!
