Low voltage. Check all your supply connections and ground.
Low voltage will cause the motor to draw more amps (to consume the same number of watts) -- and that will trip the breaker.
Electrical power is measured in watts. In an electrical system power (P) is equal to the voltage (V) multiplied by the current (I).
P = VI
