One more thing Jack
If you measure voltage at the windlass motor and it reads normal (above 12.1 depending on charge state) it could be the battery is weak. Sometimes a failing battery reads "normal" resting voltages but doesn't have the "oomph" when you put a load on it, causing voltage to sag momentarily.
