Return to Index
Read Responses
thanks Steve
In Response To:
Well, most any motor will spin fine
another SL windlass question
why get it tested then refurbished? It doesn't work, that test is done, now it needs to be refurbished...
I think that was the order I meant
Recently helped a friend with a PowerWinch.
It's a pretty simple test. Check for
Also, I have a SL Sea Wolf windless that
Steve, let me ask you a question...
Low voltage. Check all your supply connections and ground.
One more thing Jack
yes, I replaced the battery in the spring...
thanks Steve
perhaps the windlass needs servicing........
