Exactly and viscosity is simply a physical property of a fluid...
Rich might just as well have said no density no lift. The fluid's viscosity is certainly a factor in determining the amount of lift generated in a given situation, but the basic physics of the process will be independent of factors like viscosity and density. In other words, while parameters like viscosity and density will be in any proper mathematical description of lift, those parameters only impact the magnitude of lift, not the basic process itself.
