Tom,
Glad all worked out well. Fire on a boat is real scary - no place to go! It's even worse on a submarine - the fire burns the same oxygen that you need to stay alive.
Definately put a fuse on the alternator output. The cable is sized for max alternator current - the fuse should be too. Size it to protect the cable.
