Return to Index
Read Responses
Thanks Corbet. I'll do that.
In Response To:
Fuses
Going through a nasty Nantucket Sound last week, I was recalling our last time through when we lost steering.
Alternator fuse
Alt fuse
You're correct in that the wire that burned is the line that energizes the alt field through the regulator.
Fuses
Ideally every wire on the boat is either fuse or breaker protected,
If you do find one John, let me know what and where Yanmar located it. Thanks.
