Return to Index
Read Responses
Sounds like an ideal spot.
In Response To:
OK to mount a radar reflector immediately below the radar?
I wouldn't be concerned unless it was within about 20-degrees of horizontal relative to the radome.
I like it, but pole might block it.
That's where I have mine mounted
Install fo reflector
We present a strong target the majority of the time
Why don't you mount the passive device on the front of the mast ?
I don't think the radar
Do you guys know something I don't about Max's pole?
" . . . but before I go an drill a bunch of holes in the radar pole"
that is an indellicate question
*yikes
My thoughts on mounting it on the stern pole
Highly unlikely...
We have Lensref with a hoop on the front of the fast -- 2/3rds of the way up.
Thanks SG & all - perhaps I'll reconsider and put it on the mast
We solved the radar reflector on TPIII two different ways!
