Best connection
solder and then use heat shrink tubing..best connection..Slide heat shrink on to one of the wires and slide it away from the end, tin both ends of the wire, then twist together and reheat solder to finalize the connection, let cool slide tube back over the connection and use heat gun to shrink it..
