Return to Index
Read Responses
Why would you leave the gear in reverse?
In Response To:
Into reverse to fold the prop, hang the key on gear shift to remember before restarting engine
I have a flex-o-fold folding prop, and do exactly what Tim does.
http://www.sailblogs.com/member/curlew
When sailing, what do you do with your engine transmission? Reverse/Neut/what?
Yanmar advise's to put it in reverse when sailing...
Thanks... I didn't really see this recommendation anywhere in the manual...
I put mine in reverse but I have folding prop
reverse to fold the prop, then neutral
I have a MaxProp feathering prop and I do what Tim does ... Cheers, John
If you don't have a feathering or folding prop, then the prop will start to free wheel (unless you're going too slow).
My response was to a poster who has a folding prop.
Ahh, I didn't notice that :^)
Here's what Hurth says
folding prop
I leave it in reverse out of habit
Atomic 4 in Tartan 30
I put mine in reverse..
What Todd says!!!
I put mine in forward - Autoprop...
Here's the official word from Yanmar
Wow, that changes everything. Thanks
As you hear your prop free wheeling ... remember, Yanmar takes no responsiblity for your cutlass bearing, shaft seal/
but with the gear in reverse it's a brake.
Doesn't make any sense to me either. If in reverse it's stopped. Free-wheeling's got to be worse for the tranny.
It is a brake -- but not a real brake
I have to do that
I spoke w/ Mack Boring (after trying the Yanmar number and being referred) -- Surprise, to me...
Crappy engineering
This is why I like the Hurth transmission....
Curious about "Tyr that with a Yanmar"
Most Yanmars actually have a Kanzaki transmission...
I suppose they vary by engine model
That's odd - it is exactly opposite from what the distributor told me to do
Whir, whir, whir, whir,whir, whir, whir, whir,
