Concerns
In Response To: 2 concerns with gas gensets ()
Would only run briefly, and would put on deck, in cockpit or foredeck. Would use the gas container from the dink. My fridge will not run unless the engine or on or there is 'shore power' attached (would use the generator as a shore power substitute). It would be quieter and more efficient than running the diesel.
