Return to Index
Read Responses
Maybe your leak is on the pressure side of the lines?
In Response To:
We are out, winterized and shrink wrapped for the winter
How much per foot (sq foot?) does it cost to shrink wrap your boat?
not much, DIY
harbor freight gun
Wow! Here it is.
LOL! Favorite product review...
harbor freight quality
Mostly crap. Sometimes it doesn't matter, usually it does
Yep, ditto Larry
But may be perfect for the task at hand...
ahemmm.....I hope everyone reads this
Yeah a windlass is great to have
I think he meant the hole saws!
I know -- just joking Dave
I knew about cook-ie-hole cutter, but others might not remember.
I like the handle on the top of your little vacuum...must be the second generation.
And at home!
Wouldn't he hear the pump running at odd times...
Yes. It would turn on once in a while when faucets are off
Spend the night on board... you'll hear everything.
alternatives
we have both
Hopefully not. I would suspect a fitting in the line
I don't leave that breaker on
But did you leave the lines pressurized when you shut it off?
headed down to the boat tomorrow
That didn't work
Poly tank? In that long ago and faraway galaxy
Tank was fine, it was new crew you needed...
