The PDF brochure says...
minimum operating pressure 10 psi. Maximum 125. I use a 20 psi switch on my water pump but the most common is 40 psi.
I use a Seagull IV now and only need to replace them every year or so. I too have a separate tap for just drinking/cooking water and prefilter all water with a wrapped cord filter.
