WD-40 is a solvent and oughta clean the oil off. I agree...unless.......
In Response To: WD40 ()
If you want to really clean them up then you gotta soak them in....something solventy then clean them up manually. Even solid brass hinges and such are pretty cheap in the hardware store these days.
