in our boat, I came up with the conclusion that I would NOT do it again! And after over 4 years of full time cruising, and many years of living aboard, AND seeing all of the trouble so many cruisers have with reefers, I STILL stand by my conclusion.
***** Build a shelf, drop an Engel unit on it and strap it in!!! LOW power usage and reliable as a brick! *****
If you have not seen my install, you can take a look and read about it at: http://www.svguenevere.com/prep/proj/freezer/
