Could be a lot of factors?
Assuming that they both had adequate ventilation and had the same heat load from their position...
Do you attribute that to the insulation of the box, door, etc.? Is the power draw of the compressor, when operating that much different? (i.e. HP of motor, compressor load, etc.)?
Is the system that much different, Greg?
